#1 Posted : Friday, 30 April 2010 7:09:28 AM(UTC)
Just wondering if someone can measure and let me know the diameter if a HQ 350 aircleaner housing please.
Thanks in advance . . . RigPig
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin)
Oily Offline
#2 Posted : Friday, 30 April 2010 8:10:50 AM(UTC)
Oily
Hi RigPig
My late HQ housing (low comp piston smog engine )The outer diameter of the lid is 15 1/2 inches or 395 mm. The body 14 3/4 inches or 375 mm.
Oily
#3 Posted : Saturday, 1 May 2010 10:39:42 AM(UTC)
Thanks Oily
#4 Posted : Sunday, 9 May 2010 11:03:31 PM(UTC)
Can anyone spot the difference between a late 74 HQ 350 airfilter assembly and a 1970 1972 L48 Camaro 350/300HP airfilter assembly?
I think they're the same thing, but $600 cheaper.
Same diameter.
- L48 Camaro 350/300HP -
eBay item number: 330424865131
eBay item number: 150437449016
59 Cadillac Coupe Deville
74 HQ GTS4 308 Cyan Blue (should be Orchid Metallic)
74 HQ GTS4 350 Barbados Green
06 Nissan 350Z roadster
justgm Offline
#5 Posted : Monday, 10 May 2010 1:27:40 AM(UTC)
justgm
The 350 air filter assembly has part 648599 as early , 6485242 as late , but I think it is just that late has pre heat and early does not , it looks like they both use the same lid ( not listed as a part on its own ) . they must have been off something chev ? I also have a listing from my other parts book (early ) of 2820106 ? Mark.
#6 Posted : Monday, 17 May 2010 8:12:07 AM(UTC)
Just received my 1970 1972 L48 Camaro 350/300HP airfilter assembly from the states and it seems to be exactly the same as a 74 HQ 350 airfilter assembly.
$40 + $60 delivery = bargain
Guest (5)
