#1 Posted : Friday, 7 May 2010 2:01:32 AM(UTC)
Are VU IRS ute springs interchangable with 99 WH Statesman IRS springs.
I know the return rate will be different, but I need harder springs as I am changing the WH from Self leveling shocks to gas & I suspect the VU ute springs would be a equivilant to H.D. sedan springs??
been offered the VU springs for nix, otherwise another $120 for springs.
thank's
Kevin
bluHJ Offline
#2 Posted : Friday, 7 May 2010 6:31:46 AM(UTC)
bluHJ
Kevin
Ute and station wagon springs are the same in VY and VZ so I can only presume the VU ones would be as well. The sedan
ones are different. I don't know what but all the codes are different. I went to the King Spring site to check what was
interchangeable. Worth a try.
cheers...bluHJ
#3 Posted : Friday, 7 May 2010 7:25:40 AM(UTC)
Yes, they will fit.
Remember to release the handbrake when you go to fit them, otherwise the arms don't droop enough.
#4 Posted : Saturday, 8 May 2010 2:32:10 AM(UTC)
thank's
