hainzy Offline
#1 Posted : Tuesday, 18 May 2010 9:21:22 PM(UTC)
hainzy
Dont know if that title makes sense but I have a HZ radiator support here which still has the air con condensor/radiator thingy attached to the front. It has 2 pipes attached which leave the rad and enter the rad support through 2 holes just above the right bracket which attaches to the chassis.. As i dont have another one here to compare to, can someone tell me if these 2 holes are in every rad sup panel or are they only there on cars that had factory air con?? Cos it will effect which panel I use on this sandy.. Cheers for any help.
sawjew Offline
#2 Posted : Tuesday, 18 May 2010 11:27:54 PM(UTC)
sawjew
The holes are only there for air con models but all rad support panels have dimples for the centre of the holes so you can drill them out with a hole-saw. the pipes come through in the middle of the reinforced section where the bracket attaches. I have done this a couple of times before and it's no hassle at all.
Steve
Steve
HK1837 Online
#3 Posted : Wednesday, 19 May 2010 1:56:44 AM(UTC)
Ar above^^. Dimples are the same as what you find on the firewall for the holes for A/C heater core, vacuum line and TH400 speedo cable.
hainzy Offline
#4 Posted : Wednesday, 19 May 2010 5:06:41 AM(UTC)
hainzy
Thanks guys. I didnt notice there was a difference until today. i ended up drivin up to my shed to get the spare one anyway which didnt have the holes as it turns out, so glad i did... Cheers.
This page was generated in 0.022 seconds.
