BIGCAV Offline
#1 Posted : Friday, 21 May 2010 8:35:05 PM(UTC)
BIGCAV
hey guys.
at the moment we at rare spares are after some information on the hq-wb and lh-lx torana wiper linkage clips.
i have attached some photos of the clips we are after, even if u have an accurate photo of an ORIGINAL clip from those models so we can differentiate between the random sample of linkage clips i have here already that would be greatly appreciated.
hq-wb:
lh-lx:
classic oz wreck Offline
#2 Posted : Monday, 24 May 2010 10:05:12 PM(UTC)
classic oz wreck
you have 2 number 10s arrowed..same clip...your number 13 in lh lx is the same clip as hq to wb..
www.classicozwreck.com.au
#3 Posted : Tuesday, 25 May 2010 7:58:55 AM(UTC)
I think if you look at the Mitsubishi they have a very similar clip, not sure which model.
BIGCAV Offline
#4 Posted : Tuesday, 25 May 2010 7:02:30 PM(UTC)
BIGCAV
thanks john, ill have a look around
thats whats odd, the photos apear different but according to the genuine catalogue they are the same part number for all 3 clips
jabba Offline
#5 Posted : Tuesday, 25 May 2010 7:49:48 PM(UTC)
jabba
The images of 10 and 13 are the front and back view of the clip (effectively). I don't want to take a photo of mine (took ages to get to stay put after the centre section which locks it into place broke off). There is a "keyhole" shaped hole in the top bit (that you are looking at in the number 10 view). The back has a metal tang with a cross bar, that as you compress the clip and slide onto the groove around the shaft locates and locks onto the slot across the shaft. It is a bugger to describe and an even bigger bugger to figure out in the dark and tucked away in the cowl panel. Without the metal t piece, the clip works its way loose and pops out every dozen or so revolutions of the wiper motor. Unless you manage to bend a piece of number 8 wire just so and can wedge it into the clip and through the slot.
sstorana Offline
#6 Posted : Tuesday, 25 May 2010 10:01:29 PM(UTC)
sstorana
Originally posted by BIGCAV
hey guys.
hq-wb:
lh-lx:
BigCav
With regards to your pictures, for the LH/LX diagram, there is actually three clips used. They are Item Numbers 4, 10 and 13. These clips are as follows;
4. Clip - Drive Link to Wiper Motor. Pt no: SP1986 QTY: 1
10. Clip - Driven Link Attaching. Pt no: SP2383 QTY: 2
13. Clip - Drive Link to Pivot. Pt no: SP2383 QTY: 1
As you can see, the SP2383 that is used on the HQ, is also used on the LH/ LX and UC.
Edited by user Tuesday, 25 May 2010 10:02:13 PM(UTC)  | Reason: Not specified
#7 Posted : Tuesday, 25 May 2010 11:06:31 PM(UTC)
classic oz wreck
why?
BIGCAV Offline
#8 Posted : Wednesday, 26 May 2010 7:13:50 PM(UTC)
BIGCAV
hey guys.
hq-wb:
lh-lx:
BigCav
yes that correct, but just incase u missed it your number 10 and number 13 are the same part number and hence the same clip so there is only the 2 types of clips from my understanding
all the ones pictured with arrows and colored blue in the hq an lh-lx pictures are all the exact same clip
i was only after info on this 1 clip as its the one im having issues with at the moment.
thanks for the reply
cav
sstorana Offline
#9 Posted : Wednesday, 26 May 2010 8:01:06 PM(UTC)
sstorana
CAV
so are you doing just that clip or the other one as well?
BIGCAV Offline
#10 Posted : Wednesday, 26 May 2010 8:30:50 PM(UTC)
BIGCAV
for NOW it will be just the sp2383, the other may come in the future but the sp2383 is the priority at the moment as it was a product we sold untill last year and we would like it back again A.S.A.P
sstorana Offline
#11 Posted : Wednesday, 26 May 2010 9:13:25 PM(UTC)
sstorana
No Probs
hey, a little "off topic", what is the status of CP1202??
BIGCAV Offline
#12 Posted : Wednesday, 26 May 2010 9:16:54 PM(UTC)
BIGCAV
unless theres something in regards to that im unaware of im presuming you mean stock on them?
if so we received them just recently and theres a few in the wharehouse now
sstorana Offline
#13 Posted : Wednesday, 26 May 2010 9:38:41 PM(UTC)
sstorana
Thanks Cav
I was wondering if these were in Stock yet.. I will order them thru my local rep
LXCHEV Offline
#14 Posted : Monday, 19 July 2010 8:25:11 AM(UTC)
LXCHEV
LH-LX:
Hi guys,
After some discussions with Cav over on the GMH-Torana forums, we discovered something very interesting regarding this clip above (Part No SP1986 for the drive link to wiper motor on LH/LX)...
Cav kindly sent me a Rare's "C5ZZ17531A" which is a clip to suit XR-XC Ford... see pic below... and guess what... it's a perfect fit! I trial fitted one to my LX Hatchback today and it snapped into place like a dream, a nice tight fit with no slack. Absolutely rapt. Thanks again Cav.
Here's the item in question:
Brett.
BIGCAV Offline
#15 Posted : Monday, 19 July 2010 7:11:06 PM(UTC)
BIGCAV
thanks for the feedback brett, glad it worked out for you
just to clarify the above clip fits the wiper motor on lh/lx and the wiper motor and linkages on lc/lj
ill be re releasing them in there own holden packages soon
thanks again brett
Guest (13)
This page was generated in 0.095 seconds.
