Joined: 30/04/2005(UTC) Posts: 485  ![New Zealand New Zealand]() Was thanked: 16 time(s) in 15 post(s)
Hi , does a VK 5speed fit in an HK trans tunnel ? Is a 6cly monaro which has a p/g at the moment ? Any one fitted one ? Mark.
VE-ssv ,VT-gts ,VH-royale , LH-SLR5000 ,LJ-gtr ,HQ-350-prem , HQ-el-camino ,Gemini-zzt &zzr . |
life is good in "Wine & Holden Marlborough " |
Seriously doubt it. Aussie 4sd needs body member mods so one of those probably will too. You are best of sticking with Saginaw or Muncie. Either of these also needs mods for linkage clearance but as per factory Saginaw fitted HK-HG.
