#1 Posted : Sunday, 13 March 2005 4:25:24 AM(UTC)
Wb ute has bad shudder in front end at about 80km/h. have replaced drag link, tyre rod ends, ball joints, idler arm bracket, control arm bushes. Iam now at my witts end as to what is causing the problem, any ideas or suggestion would be received openly.
#2 Posted : Sunday, 13 March 2005 6:17:11 AM(UTC)
Does it get worse if you go faster? If it does, I'd suspect wheel balance or a bent rim or a bubble in the tread of one of your front tyres. Try putting your fronts on the back and backs on teh front and see if there is any change.
The only other thing
#3 Posted : Thursday, 17 March 2005 3:56:31 AM(UTC)
have swapped the front and back around and has made a big difference, although there is still a slight shudder now. I am going to buy a new set of mags and tyres.
Thanks for the advice Qute.
#4 Posted : Thursday, 17 March 2005 8:02:59 AM(UTC)
Cool! Thanks for letting us know what it was.
Cheers...Dave
#5 Posted : Saturday, 26 March 2005 3:36:31 AM(UTC)
I let a mechenic take the ute for a drive and he informed me that the tailshaft has a slight warp in it as well.
