toddyg Offline
#1 Posted : Friday, 2 July 2010 3:33:42 AM(UTC)
toddyg
even under light braking,sometimes one front wheel will lock up pulling up at lights ect,it is a hq 308 with 5" runners up front.could this be to much weight on skinny front rims.any advice or
ideas welcome
#2 Posted : Friday, 2 July 2010 8:30:33 AM(UTC)
most likely grease from hubs or brake fluid leaking onto linings if it was the thin fronts I would think both would lock up. easiest way to check is to throw on a set of bigger fronts.
I would assume they are disk brakes?
This page was generated in 0.017 seconds.
