Gyro Offline
#1 Posted : Friday, 9 July 2010 5:58:53 PM(UTC)
Gyro
Hi,
my 202 (red motor) carby needs some pro advice. Engine & carby are fully done up 25,000 miles back & slowly carby has altered over last 6 mths. I dont need choke at all in a startup in a frost. 15 seconds after starting she tries to flood so I rev her a little til it subsides. Takes 10 minutes to come right & not stall at lights etc. A mate says I have float problems/leak. Sure sounds a possibility; is this where I should start looking? Getting worried. Should I clean out the breather hose from rocker cover to carby? Someone said it can foul up. But after 25,000 miles?
bambino Offline
#2 Posted : Saturday, 10 July 2010 2:19:08 AM(UTC)
bambino
You'd probably get more info/replies if you put this question in the Holden part of this forum.
BIGCAV Offline
#3 Posted : Saturday, 10 July 2010 2:30:24 AM(UTC)
BIGCAV
thats a good point bambino
id be looking at replacing the needle and seat initially
Gyro Offline
#4 Posted : Saturday, 10 July 2010 2:49:36 AM(UTC)
Gyro
[quote]Originally posted by BIGCAV
thanks guys. hope i can find my way there.
