adam PERTH Offline
#1 Posted : Sunday, 18 July 2010 7:28:11 AM(UTC)
adam PERTH
Got a VJ prefix 304 and was just wondering how the long motor differs from a 308 blue motor (apart from bore x stroke)
did they have a better set of conrods?
Wanted : HJ statesman Rear venetian blind aus wide
#2 Posted : Sunday, 18 July 2010 7:55:51 AM(UTC)
Heads have bigger valves and deshrouding around the valves plus hardened seats for ULP. I think the valve deshrouding is one way the compression was lowered for ULP. AFAIK they had the same X rods (like VK, similar to L34) until the A9L (VL Group A) then as far as I know all 304 engines past that time had the A9L style rods. So basically heads, rods, crank and pistons are different to 308 blue.
#3 Posted : Sunday, 18 July 2010 8:11:21 AM(UTC)
The inlet is the equivalent of the VH/VK HDT big port one - same '955 part number, but with with a 4-hole flange where the carby bolts on (unlike the open flange on the HDT ones).
VH with the V5H engine, VH SS 5L, VK V5H engines, VK manuals from '85 onwards, and late VK autos got the L34 type rods, and these continued in the VL 304. A9L rods were only factory fitted to VL Group As.
Pistons in the VL motor have a dish in the centre of them - about 50mm in diamter by a few mm deep, which drops the compression.
Heads are big-vlave, like the VH & VK B-cast heads - only the exhaust valve seats are hardened (induction).
Block is still the same (all black 5L are trimatic pattern though).
Crank is still the same as VK 304, which is actually the same casting as the 308 blue, but with the big-ends offset ground to reduce the stroke slightly - this is why your crank will still have 308 cast into it (like the early EFI ones do too).
A blue 308 crank will drop into a VL 304, and everything will still bolt up to it.
#4 Posted : Sunday, 18 July 2010 8:40:15 AM(UTC)
And the statement I meant to write at the bottom was "Mick will be able to tell you exactly what is different"!!!
Mick, I remember reading somewhere that VL heads weren't decked once the valves were deshrouded, hence gave even lower compression. True or myth?
#5 Posted : Sunday, 18 July 2010 9:04:25 AM(UTC)
Nothing different in the head's deck dimensions - drop them on a blue 308 and there's no change.
