YetAnotherForum.NET Help
HotRodder Offline
#1 Posted : Sunday, 25 July 2010 5:54:47 AM(UTC)
HotRodder
We bought a HQ utility today less a motor which has a v8 diif so I'm wondering will this diff be alright to use with a 202 engine.
adam PERTH Offline
#2 Posted : Sunday, 25 July 2010 7:13:52 AM(UTC)
adam PERTH
yes, you will need to use the V8 tailshaft with it..
check the ratio, if its 2.78 it will be too tall for 202
Tuning for Holley carbs in Perth? PM me.
HotRodder Offline
#3 Posted : Monday, 26 July 2010 12:37:58 AM(UTC)
HotRodder
Where do I find the ratio figure.
AMunro327 Offline
#4 Posted : Monday, 26 July 2010 5:53:30 AM(UTC)
AMunro327
It's usually stamped into the metal cover over the pinion seal. To be really sure, count the teeth on the pinion and the crown wheel. Hypothetically, if the crown wheel has 30 teeth and the pinion 10, the ratio is 30:10 or 3:1
adam PERTH Offline
#5 Posted : Monday, 26 July 2010 7:41:43 AM(UTC)
adam PERTH
an easy way is to jack 1 wheel up and cound how many HALF turns the tailshaft does in 1 full turn of the tyre.
this is your ratio.
