toranamike Offline
#1 Posted : Monday, 26 July 2010 10:23:59 AM(UTC)
toranamike
Hi guys,
I've got an LX 202, and was wondering if I fit an HEI distributor to it, does it have to be regraphed?
#2 Posted : Monday, 26 July 2010 2:35:39 PM(UTC)
Yes, a WB/VC through to VH 6cyl or VK EFI dizzy will fit straight in. You'll need the coil and leads too, and bridge the start & run wires together at the ignition switch (as the HEI coil needs full 12V). Regraphing would be a good idea but it will run OK.
