275monaro Offline
#1 Posted : Thursday, 12 August 2010 12:44:11 AM(UTC)
275monaro
hi i have a 75 hj gts of a night time the dash lights are very hard to see not very bright even with dimer turned all the way up any suggestions on best way to fix this also does any body know how many hj gts where painted in jade green
cheers denis
petaus Offline
#2 Posted : Thursday, 12 August 2010 3:24:24 AM(UTC)
petaus
i would pull the dash out and check the bulbs first might be half burnt out (black)
pete.
#3 Posted : Thursday, 12 August 2010 4:41:11 AM(UTC)
the dash lights in my HQ were very dull
i pulled the lenses out to check the globes and i noticed the lenses were covered in heaps of dust on the inside, i cleaned the lenses and it made a big difference
it could also be the globes are stuffed
275monaro Offline
#4 Posted : Thursday, 12 August 2010 5:38:01 PM(UTC)
275monaro
will give that a go i have had this type of dash before and cant remember them being so dull is there are led replacement type of bulb available for them
sawjew Offline
#5 Posted : Thursday, 12 August 2010 11:34:07 PM(UTC)
sawjew
I had the same issue with my HJ so I put LED replacement globes in. All lovely and bright but they keep blowing so I have gone back to the standard globes.
You can get the standard globes in 3W and 6W, make sure you put the 6W ones in and you should have no issues.
Steve
Steve
This page was generated in 0.122 seconds.
