#1 Posted : Thursday, 17 March 2005 4:38:01 PM(UTC)
Does anyone have a wiring diagram for a VR T56 gearbox, or know where I can obtain one?
The VR manual doesn't show the 6 speed box, and the 5 speed T5 is entirely different :-(
#2 Posted : Friday, 18 March 2005 5:19:00 AM(UTC)
which VR had a six speed?
DO NOT WRITE BELOW THIS LINE
#3 Posted : Friday, 18 March 2005 5:38:00 AM(UTC)
Any VR HSV with the 5.7L had the T56 as an option.
#4 Posted : Friday, 18 March 2005 5:53:58 AM(UTC)
okey dokey.
new fact for the brain bank.
i cant imagine them being overlly complicated in terms of wiring.
which part exactly are you having problems with
are you re wirng the whole thing, replacing a sender plug etc?
Taz2 Offline
#5 Posted : Friday, 18 March 2005 4:30:01 PM(UTC)
Taz2
I'm more concerned with the wiring in regard to the cruise control. No problem with the reverse ligt switch or the speed sensor. If I could get hold of suppliment info/manual or an option manual, that might help. Stroker engine & box is going in a VN.
In thrust we trust
#6 Posted : Friday, 18 March 2005 10:34:13 PM(UTC)
There is a switch in the remote clutch master cylinder housing on the side of the box. Run 2 wires off this, and join them in series to the brake pedal cutoff switch in the car - it really is that easy Bruce.
Basically all it effectively does is cuts
Taz2 Offline
#7 Posted : Saturday, 19 March 2005 5:53:21 AM(UTC)
Taz2
G'day Mick.
Can you send me your email address (I had a pooter crash & lost everything), and I'll send you a pic of the latest VN update.
Bruce
In thrust we trust
#8 Posted : Saturday, 19 March 2005 6:46:24 AM(UTC)
should take 10 minutes.
but use solder, not crimps or "twist and tape"
it would cop alot of the elements and crimps or twists will corrode eventually
Guest (6)
