twin turbo HT Offline
#1 Posted : Friday, 20 August 2010 7:30:41 AM(UTC)
twin turbo HT
how do i get a trimatic to grab 3rd under boost with no manifold vacuum ????? can i use the turbo inlet housing ????
#2 Posted : Friday, 20 August 2010 6:04:18 PM(UTC)
When you do a turbo conversion, all of the old inlet manifold old vacuum hoses & pipes are now connected to the manifold between the throttle body (or carby) & the turbo intake. This is especially important for the PCV, transmission modulator or brake booster.
About the only vacuum connections that I can think of that should be connected to the boost manifold would be distributor advance (if you have one) & any MAP sensor or boost gauge.
#3 Posted : Sunday, 22 August 2010 6:46:16 AM(UTC)
the only way is to use the power of ORP
#4 Posted : Sunday, 22 August 2010 6:56:48 AM(UTC)
manual valve body trans.
Jim in Adelaide...DONT LISTEN TO BULLS@#T LONGER THAN YOU HAVE TOO!
blissy Offline
#5 Posted : Sunday, 22 August 2010 9:43:58 PM(UTC)
blissy
pmsl
And your cry-baby whiny-assed opinion would be...?
186s
