jphick Offline
#1 Posted : Monday, 21 March 2005 3:26:57 PM(UTC)
jphick
Is it easy enough to swap the two lower panels on HQ Kingswoods, that run between the rear of the front wheel and the front of the rear wheel,(Could someone please tell me what these panels are called?) with the chromed(?)panels/sections that are on HQ Premier sedans?
I,m looking for an easy way to cover up/remove the rust in this area.The worst bit of course is just behind the front wheel at the bottom.Is that part of the front guard or is it a seperate section independant of both the front guard panel and the strip that continues on to the rear wheel?(I,m in Denmark ,HQ in OZ,would just look if I could)
Cheers,Paul
Taz2 Offline
#2 Posted : Monday, 21 March 2005 4:45:46 PM(UTC)
Taz2
It's called the rocker panel or sill panel.
The rusty bit at the front under the chrome strip is the lower section of the front guard.
Those premier chrome strips have a lot to answer for....excellent rust promoters!!!
Replacing the sill panel is a fai
In thrust we trust
jphick Offline
#3 Posted : Monday, 21 March 2005 5:55:30 PM(UTC)
jphick
Thanks for that Taz.So by replacing the front guard is the other way to get rid of the rust in that section(Not good at welding,should have two rust free panels soon!).The section back from that towards the rear wheel is not too bad,so should be able to
