#1 Posted : Tuesday, 22 March 2005 4:21:51 AM(UTC)
Hey I know it's a whole lot of hassle getting to these speakers but what's the best method? I took all the front of the dash off before but I didn't seem to get any closer. Anyone got any tips or an easy way?
Thanks in advance.
#2 Posted : Tuesday, 22 March 2005 4:34:13 AM(UTC)
Sorry to double post but what size are these speakers?
#3 Posted : Tuesday, 22 March 2005 5:30:08 AM(UTC)
Heya there just std 4" speakers problem i found with my vl when i replaced them is newer speakers are deeper and right under the holes is the air con ducting so it dosen't leave you much room i found panassonics fitted the best as for removal theres 2 sc
#4 Posted : Tuesday, 22 March 2005 6:08:26 AM(UTC)
When i had my VL.i found poineer 4 inch speaker fitted well also.To get the screws undeer the front window. i used a small phillips head that you would put in a drill. i used a 1/4 drive socket and ratchet as i couldnt move the screws with anything else.
