wayne hj owner Offline
#1 Posted : Saturday, 18 December 2010 2:48:47 AM(UTC)
wayne hj owner
can get all lights,parkers and blinkers working except for front left blinker and parker any idea.
Oily Offline
#2 Posted : Saturday, 18 December 2010 5:18:47 AM(UTC)
Oily
Wayne I take it that you have tested for presence of power at the lamp.
The bulb holders or lamp assembly earth (or lack of it)will most likely be the problem, Ensure that the bulb holder is not rusty. You can use a jumper lead from the battery negative to the bulb holder to check this.
Another thing that can catch you out is if the locating tag on the sprung loaded contact plate is worn and lets the contacts spin (Dual filament bulbs only)normally on tail lamps.
Modern cars do not commonly have these problems that are common on older beasts because they run 2 wire to every lamp, one for power the other for earth.
good luck oily
#3 Posted : Saturday, 18 December 2010 7:45:23 AM(UTC)
wayne hj owner
thanks oily got it sorted was bad earth.
wayne
