cheezel308 Offline
#1 Posted : Friday, 24 December 2010 1:58:56 AM(UTC)
cheezel308
hi guys it's been awhile!!...anyway i've brought a HG and it's got new interior but the base's of the front bench seat that bolt to the floor are stuffed (believe it or not)...
so my question is..are they welded to the under side/frame of the seat?..or can you un-bolt them!?!
i hope you guys can make sense of this......
cheers Mick.
Oily Offline
#2 Posted : Friday, 24 December 2010 7:41:22 AM(UTC)
Oily
Hi The adjustable slides should be bolted on with small 1/2" bolts at each end similar to the bucket seat jobs. Just slide the track back and you will be able to get one bolt out then slide it back the other way to access the bolt at the other end. There is also the adjuster wire but that is easy. If you are a contortionist you probably can do the job in situ as you will have already lost skin and temper getting the bolts out of the floor. Oily
cheezel308 Offline
#3 Posted : Friday, 24 December 2010 4:54:40 PM(UTC)
cheezel308
awesome thanks oily......now i've just gotta find a donor seat!!!
Edited by user Friday, 24 December 2010 4:55:26 PM(UTC)  | Reason: Not specified
