Hey guys,
Just wondering if anyone has a column shift auto set up for a uc torana, mine's column manual and I want a column auto so the missus can drive it. I would prefer one locally but I should also be able to organise pick up by a courier.
Cheers Dave
Dave
Call Greg at Classicozwreck on 0249598999. He'll have one out of a LH-LX if not UC. You want the column, shift rod and rotator and probably the UC column auto indicator. The wiring will be under the dash to plug into the column detent switch, you'll just have to remove a bridge plug from the harness that the manual cars have. You might find the diff is a 3.55:1 too and may be no good for a trimatic, just look around for a UC 3.08 replacement. Make sure you don't just get any old UC trimatic either as many were LH shift boxes. You want a RH shift box for a column shift.
looks like I'm getting the whole set up from toowoomba pretty soon
Cheers Dave
