adam PERTH Offline
#1 Posted : Thursday, 27 January 2011 9:35:46 AM(UTC)
adam PERTH
after about 4 years of production, what is the verdict on the series 1 VE commodore??
Tuning for Holley carbs in Perth? PM me.
#2 Posted : Thursday, 27 January 2011 4:29:23 PM(UTC)
They're pretty good cars.
Yes, they do have some known faults, which are really no worse than any other make/model.
You can't deny they are great value - you get a lot of metal for your money, reasonable running & reair costs, and an A/C system that copes well even on the hottest days.
I've had one as a company car for a while (V6 Omega - turns 4 today actually), and bought a V8 Calais V for my wife to drive. It was an upgrade from a very reliable VS we'd had for years, and I wouldn't have bought it if I didn't think they were good cars.
#3 Posted : Thursday, 27 January 2011 6:13:00 PM(UTC)
When I retire the CV8 in a year do you think the VE Calais V is a worthy replacement (the CV8 will get parked in the shed corner). Is the VE that much bigger than the V2?
#4 Posted : Thursday, 27 January 2011 8:59:51 PM(UTC)
The VE looks good, but the statesman looks exactly the same IMO, I find I have to look very close at them to see that it is a stato & not a Calais, the wife wants the SS sports wagon in poison Ivy...
#5 Posted : Friday, 28 January 2011 7:17:34 AM(UTC)
You'll find the VE isn't that much bigger physically - it's certainly less of a step from VT/VZ up to a VE than the step from VS>VT.
One thing you will find in the VE, is that the car seems to get smaller as you drive it. As a stock package, they handle very well - making them feel smaller & more nimble than they really are.
One area you will appreciate in the VE (compared to VT-VZ & variants) is the boot space. It's a much better boot, and while it doesn't seem to look like it's that much bigger, it holds a lot more than a VT-VZ when you pack it well - and the VE boot hinges certainly help here.
The 6.0L is a much better engine than the 5.7L, and the economy they get is quite good. The 6 speed auto does take a bit to get used to - if you drive it like a granny for a while, then give it a bit of a squirt, it seems to want to get lazy & skip gears. "Sport" mode is quite harsh at light throttle openings, but once you get used to "driving" it, the box works well.
The downside to the VE is that DIY repairs are becoming a thing of the past with these cars. This does suit the majority of buyers though, just not those of us who like to do our own work.
#6 Posted : Friday, 28 January 2011 7:40:39 AM(UTC)
If you like a bit more grunt than the omega(180kw ,4spd auto)) go for a calias or sv6 with 195kw , the high output 6 also gives you the 5 speed auto(up to 2008)I think.
I have a 07 WM with the high output 195kw -v6 and they go quite hard when pushed (Wheels mag says 15.4 secs /400 meteres), we have done about 20,000klms since buying it with no issues, the car has done 52,000k`s.
#7 Posted : Friday, 28 January 2011 8:47:44 AM(UTC)
If I get one it'll be a Calais V ie 6L. I wouldn't have a V6 ever again, damn horrible things. I'm suffering one right now in the 2010 SR5 Hilux I have, but there is nothing else available and if nothing else comes up i'll change it to a 6.0L GM engine when the warranty expires.
#8 Posted : Friday, 28 January 2011 8:12:40 PM(UTC)
I have had a few v6 Holdens the only problems have been age related, when we sold our V6 96 VS statesman it had done 310,000k`s and still going strong.
The 6L is nice but I have enough V8`s to register with the old cars.
The mother in law has a 6L calias V in evoke plenty of grunt,a mate has a 6L caprice 06 model I asked about the fuel economy he says on the hwy 10/100 and 12/100 in the city ,he`s not a lead foot..
#9 Posted : Saturday, 29 January 2011 3:43:57 AM(UTC)
That's what we're getting cloudy - around town it's in the 12s and the open road can dip into the low 9s if there's not many hills. I find I use less on the open road by not using cruise control, which is rare these days.
In NSW you don't pay any more for a V8 at rego time - it's based on the weight, and the Calais V is in the same bracket for both engine options.
We only got up to 175k in our VS before replacing it with this Calais V. Only just started to have a couple of issues - new water pump, and new power steering pump, and I put one set of brake pads into it about 6 years ago. It was otherwise perfect, but you do expect those things as normal wear & tear.
The in-law's VS stato cracked 400,000 before they sold it (replaced with a 5.7L WK Caprice). It did crack a set of heads at 250k though - caused by a stuck thermostat, but the only other probs it had was a torque convertor clutch failure, a reg in the alternator, and the idler pulley support near the coil pack broke whilst cranking - flicking the belt off. It towed a whole heap of cars around on the trailer too (rear was setup for towing) and avoided the IRS tyre wear issues.
playwme Offline
#10 Posted : Saturday, 29 January 2011 7:37:49 AM(UTC)
playwme
Your wife has good taste. Poison Ivy has to be one of the best factory colours I've ever seen and the wagon looks way smoother than the sedan.
My little sister has a SSV ute. Seems to be a good thing. Feels a lot better built than the previous models and the economy she gets on the highway with the AFM is astounding.
asdf88 Offline
#11 Posted : Saturday, 29 January 2011 7:41:32 AM(UTC)
asdf88
I reckon the 195kw v6 is a great engine. I've had mine for 3 years and it starts great, runs well and pulls the car trailer fine. The motor puts out more power than a HQ 308 and has good fuel economy at the same time.
The only real problem is the tyres. The Bridgestone 245/45R18 cost an arm, leg and some other appendages to replace. I got 40,000k�s in the V6, and I imagine the 6.0L would be even harder on them.
Regards, Alan.
