hkute68 Offline
#1 Posted : Friday, 18 February 2011 3:51:16 AM(UTC)
hkute68
i recently purchased the fire wall insulation with the three plugs supplied.i have sort of worked out where most things go but i need some pics of where the choke,heater cable come through after the insulation is fitted?some pics of this area would be great.
Its a 186,crash box with heater out of a HT.
thanks
The HKTG Garage Offline
#2 Posted : Friday, 18 February 2011 4:13:57 AM(UTC)
The HKTG Garage
The heater cable goes through the centre of one of the plugs. You snip the end of it off after installing it and feed it through. There should already be a hole in the insulation for the choke cable.
hkute68 Offline
#3 Posted : Friday, 18 February 2011 4:55:09 AM(UTC)
hkute68
i worked that much out cause the plug lines up with the heater cable position,but where is the choke supposed to come through?i have a hole behind the internal ducting but that is a bit of a bend or is it also supposed to go through a plug?
hkute68 Offline
#4 Posted : Sunday, 24 April 2011 8:31:21 AM(UTC)
hkute68
does anyone have pics of how these were fitted from factory,would be a big help.
