when travelling at 80 to 100 ks per hour and back off car is running fine but when i put pressure on accelerator i have a vibration would it be coming thru the autwayne
Maybe look for buggered uni joint(s), broken engine mount or loose torque converter bolts. |
i just checked gearbox mount it is almost non existant just one tiny peice of rubber holding it together i had the trans serviced last august and the speedo drive gear done last september u would think the mechanics would check mounts when doing these jobs as i had a spare one that was given to me. wayne
