wayne hj owner Offline
#1 Posted : Saturday, 23 April 2011 1:29:27 AM(UTC)
wayne hj owner
what is the best way to remove the rear cargo bay side window in my hj wagon removed strips around window and have a rust problem.
wayne
#2 Posted : Saturday, 23 April 2011 2:46:24 AM(UTC)
go around the rubber with a knife(since you have rust) and just push it in...carefully.
#3 Posted : Saturday, 23 April 2011 11:56:40 PM(UTC)
if the seal is ok (still soft) you can simply push the window out from the inside, you will need another person to help out, but if the frame is badly rusted you can simply use a stanley knife & cut the rubber enough to remove the glass. as jim said above..
#4 Posted : Monday, 25 April 2011 4:09:00 AM(UTC)
wayne hj owner
thanks jim & monaro 202 i reckon i will just cut it want to replace all rubbers and seals eventually.
wayne
