jayHK69 Offline
#1 Posted : Thursday, 28 April 2011 9:09:18 PM(UTC)
jayHK69
what`s involved in replacing a front guard on an el falcon ?
is it a straight forward job ?
jayson
#2 Posted : Wednesday, 4 May 2011 8:49:56 AM(UTC)
Remove the front bumper and life is much easier if you remove the front door too as you can then get at the lower rear guard bolts.
Removal of the door is easy as to do as you just disconnect the wiring, undo the check strap, loosen the 8mm headed grub bolts on the hinges and lift the door off.
Once the bumper and door are removed you can then see every guard bolt.
