#1 Posted : Sunday, 3 April 2005 6:10:54 AM(UTC)
PLEASE DON'T POST COMMENTS, "JUST SPECS" ON THIS TOPIC.
if you would like to make comments, go to Compression Ratio - "keep it real".
DO POST SPECS - If u have ever rebuilt an engine to try and get maximum compression and it DID or DID'T work (ie-Ping). Keep it simple and relating to RATIO, CAMSHAFT and PRESSURE READING.
Don't Bull**** or guess, these are facts exclusive for Fastlaners engines.
FOR EXAMPLE - (not actual)
Holden 138
Bored 3.120 in
Stroke 3.125 in
Head shaved 0.080 in
RATIO* 8.1:1
CAM* 30/70 Reground original
PSI* 140 (Cranking when engine Hot)
Comment I can run it on low grade unleaded and it still don't Ping (could have gone higher Ratio)
