peter_flane Offline
#1 Posted : Sunday, 5 June 2011 2:33:39 AM(UTC)
peter_flane
Does anyone have, or know of a reproduction panel for the full dogleg panel for it's whole radius.
It seems only the bottom 200mm of the dogleg is available as a rust replacement section.
I need the entire RH dogleg. I will consider secondhand cut, even if it needs the bottom few inches replaced.
Anyone? I will pay for part, cutting time and freight to Ringwood Melbourne.
It is worth $200 to me, even if it has a few small rust bubbles at the bottom. Contact me please if you can help.
peter_flane Offline
#2 Posted : Sunday, 19 June 2011 5:08:07 AM(UTC)
peter_flane
Still looking for dogleg panels, LH and RH.
Full length. NOS, S/H, reproduction.
What is available?
obsessed Offline
#3 Posted : Sunday, 19 June 2011 8:23:31 PM(UTC)
obsessed
I've got a HX sedan I've been parting out, I'll check the doglegs and send you some pics.
obsessed Offline
#4 Posted : Sunday, 19 June 2011 10:16:45 PM(UTC)
obsessed
Whats your email address mate?
peter_flane Offline
#5 Posted : Monday, 20 June 2011 5:30:08 AM(UTC)
peter_flane
peter_flane Offline
#6 Posted : Monday, 1 August 2011 9:22:26 AM(UTC)
peter_flane
I really appreciate your time and help. I thank you for sending the pics. I was in the right place at the right time, and got a couple bits off a HX sedan that I need. It was going to the crusher, so I saved a small bit of it.
Again thank you for your time.
This page was generated in 0.427 seconds.
