Pumpa15 Offline
#1 Posted : Friday, 17 June 2011 3:34:42 AM(UTC)
Pumpa15
Hi All,
was wondering if any of the HQ guru's could help confirm the material and size of the spare wheel spacer that was originally fitted to the HQ coupe? The spacer is used for the rallye ii type, have been given a part number 2823374?
peter_flane Offline
#2 Posted : Friday, 17 June 2011 4:04:06 AM(UTC)
peter_flane
What thickness were the spacers? Were they attached to the axle/ disc with any screws? Were the wheel studs longer?
#3 Posted : Friday, 17 June 2011 4:18:45 AM(UTC)
yep that's the right part number
if you need 1 then they can be bought from here http://hqresto.com/
Pumpa15 Offline
#4 Posted : Friday, 17 June 2011 4:28:53 AM(UTC)
Pumpa15
Thanks Davequey74,
As always there is always someone who knows where to source the right gear.
