#1 Posted : Saturday, 11 September 2004 5:45:34 PM(UTC)
I have a 1970 Fairlaine, and I am unsure what to do about fuel when the LRP is phased out, what options do I have? Will unleaded run ok without any mods? Is a higher octane fuel a risk or good value? Help
#2 Posted : Sunday, 12 September 2004 12:24:06 AM(UTC)
The LRP Fuels are goign to be dissapearing very quickly by the end of this year-it will be harder to find the stuff.
the best solution for your fuel problem is to run a 98 octane fuel (BP - Ultimate ; Caltex - Vortex etc) and then add sum flashlube
#3 Posted : Sunday, 12 September 2004 2:03:45 AM(UTC)
my motor is a rebuilt 250 x-flow (leaded xe motor)it has a good cam etc.i run normal unleaded and use flashlube,i have been using this for around 2 years because where i live in qld lrp doesn't exisit or ite 6c a litre dearer.it dosn't run hot,ping or any
#4 Posted : Sunday, 12 September 2004 10:30:42 AM(UTC)
thanks, I will give the fuel you suggest a try and let you know how it goes.
#5 Posted : Sunday, 12 September 2004 10:32:28 AM(UTC)
thanks for your comments, I'm from WA and havn't seen the "flashlube" here. is there an alternative I could use?
#6 Posted : Sunday, 12 September 2004 9:31:24 PM(UTC)
try your local super cheap/autobarn etc etc,they will tell you of a brand if flashlube isn't available there.i buy it in a 1 litre bottle for $20 and it lasts round 6 months.you can also buy a full under bonnet kit which screews to the engine bay and a va
#7 Posted : Monday, 13 September 2004 7:53:21 AM(UTC)
Odin Spares have the Moreys kit for about $65, its the same as flashlube.
#8 Posted : Friday, 15 October 2004 10:00:58 AM(UTC)
thanks.
