pfillery Offline
#1 Posted : Monday, 19 September 2011 11:37:18 PM(UTC)
pfillery
Stock standard 186 motor (186P), has a carter 2 barrel carby on standard carby manifold, exhaust manifold, comes with dizzy, leads, coil, ballast resistor, flywheel, alternator, fan, fanbelt. Needs new water pump as this one has a leak ($35 new and easy to replace). Coil not attached to engine, engine is still in vehicle and can start if you bring a battery, starts and runs well but needs tidy up and tune (as you would if changine engines), runs ok but fuel lines are old and sucking air. Starter is optional by negotiation, has landrover conversion bell housing (so it can still be started) and engine mounts on it which are not included (no good if fitting to a holden). Drove well before gearbox removed. No nasty noises and cranked quickly/started easilly.
I have an engine crane to assist with loading, still in vehicle and will remove once sold so it can be seen running, great for car or boat, located Brisbane Northside, email [email protected] for a look and make an offer.
