papaya hx Offline
#1 Posted : Monday, 7 November 2011 8:27:19 AM(UTC)
papaya hx
Can anyone give me a list of parts needed for this conversion. Car has 350 chev / saginaw in it and I would like to convert to auto. Can I use the same starter motor and tailshaft and will the current extractors still be useable? thanks Ron.
#2 Posted : Tuesday, 8 November 2011 4:15:01 AM(UTC)
Tailshaft, gearbox crossmember and speedo cable will be the same assuming it is the HZ/VB/VC/WB length TH350 (same length as powerglide and Saginaw. Starter will be the same if you use the same size flexplate as the flywheel is now (is 153 or 168 teeth). I can't tell you if extractors will fit or not. For a T-bar use a HT-HG trimatic T-bar.
This page was generated in 0.017 seconds.
