gmholdman Offline
#1 Posted : Tuesday, 10 January 2012 5:42:35 AM(UTC)
gmholdman
What,if any, models came out with muncy box.
#2 Posted : Tuesday, 10 January 2012 6:30:45 AM(UTC)
Muncie M20 was fitted as standard to only 1 x model: HQ 1837 (GTS 350 coupe). Same box was also fitted as part of special vehicle package XW8 when optioned on a HQ 0469 (V8 Kingswood sedan), package was called GTS350 sedan. All of the other HQ's that got a 350 were M41 TH400 except for 1 x Kingswood sedan that wasn't an XW8.
#3 Posted : Tuesday, 10 January 2012 8:54:14 PM(UTC)
It should be mentioned that while the Muncie has the PO code M20 in the USA, when fitted to a Holden it's code is MC7.
MC7 will probably only be seen on the body plate of an XW8, because in a GTS 350 coupe it is standard equipment.
