nhayato Offline
#1 Posted : Monday, 13 February 2012 3:50:05 AM(UTC)
nhayato
Hello,
Have been searching for this answer all day... Wanting to know 2 things...
If I want to reduce understeer on my AU Falcon Forte, can I just replace the front sway bar with a 27mm one and do nothing else?
And if I replace this, would an aftermarket link kit be better than the stock sway bar link ?
Edited by user Monday, 13 February 2012 3:52:27 AM(UTC)  | Reason: Not specified
#2 Posted : Monday, 13 February 2012 6:47:47 AM(UTC)
If you want your car to understeer put a bigger anti sway bar on the front. If you want it to oversteer put a bigger one on the back.
Thats the rule however completely removing a rear anti sway bar will likely introduce a thing called roll oversteer.
This page was generated in 0.016 seconds.
