Silverfox Offline
#1 Posted : Tuesday, 3 April 2012 6:02:49 PM(UTC)
Silverfox
Hi
Looking for a cap (Part No.7426554) for HK clutch Master Cylinder (Part No. 7433520).
Could get complete working/ non working master cyl for the bits. This part number was used for both 6cyl and V8s. Also seen them on other models.
Also 327 Thermostat housing. Mine's popped a hole. Couldn't find specific part number in the Blue cover parts book M371370 April 1972. Closest I could find was reference to thermostat assembly 315298. Anybody know the GM part number. If I cannot find a local one I guess I can hunt one down out of the U.S. Also would the Arerican part be accurate for series two 327?
Both new or good S/H.
Thanks to all.
Nick. Yamba.
Edited by user Tuesday, 3 April 2012 6:06:30 PM(UTC)  | Reason: Not specified
dirty davo Offline
#2 Posted : Tuesday, 3 April 2012 6:58:34 PM(UTC)
dirty davo
Originally posted by Silverfox
Hi
Thanks to all.
Nick. Yamba.
GM 3877660. & it had a wing on rhside for throttle return spring. i have a couple here nick
some had part# on top of outlet where hose goes on, & others had it at 12 oclock on th base
regards DD 0412109239
