Oily Offline
#1 Posted : Tuesday, 10 April 2012 8:12:53 AM(UTC)
Oily
Byron Warren
Theres a 327 on gumtree with pagewood? like numbers but is the block casting number 3903352 correct for Hk or Impala/Pontiac etc,I am not chasing this one just interesed in the numbering.
http://www.gumtree.com.a...complete-motor/358415796
Oily
#2 Posted : Tuesday, 10 April 2012 3:37:51 PM(UTC)
It is a '67 327, hence most likely a restamp as it'll be a small journal block. HK 327's with 32712xxx will all be 3914660 and just 4 x possible assembly dates all from Tonnawanda plant, Pontiac and Impala Pagewood engines have other assembly dates but the same cast number and Tonnawanda also.
Oily Offline
#3 Posted : Wednesday, 11 April 2012 5:16:14 AM(UTC)
Oily
Thanks I wasnt sure if any early Hk may have been small journal blocks Thanks oily
#4 Posted : Wednesday, 11 April 2012 5:45:03 AM(UTC)
Very unlikely. It is possible I suppose GMH tried one in an early HK but it wouldn't have an engine number like 32712xxx. Remember all 1968 Pontiac and Impala assembled by GMH in 1968 (like 6 months or more prior to Monaro) had large journal 3914660 blocks with engine numbers amongst the HK 307's so they were in widespread usage a long time before Monaro production. The first HK Monaros from Pagewood actually had enigine numbers around 30712xxx and 32712xxx.
