crackatinny Offline
#1 Posted : Friday, 22 June 2012 6:39:54 AM(UTC)
crackatinny
Going to look at a HJ Holden tomorrow thats been sitting under a tree for 10 years, and only has 140.000 KLM on it.
Any tip's where to look for rust in this model?
peter_flane Offline
#2 Posted : Friday, 22 June 2012 8:04:11 AM(UTC)
peter_flane
Roof along gutters, inside under headlining
bottom corners of boot lid back edge
bottom corners of all four doors on the outside
bottom inner corners and top inner corners of the front doors
all around the front and rear windscreens
bottom front corners of the rear lower quarter panels
top of the dogleg panels
bottom of the dogleg panels
sill panels
bottom of the front guards
front corners of the bonnet
floors
Anywhere that shows any sign of surface rust on the outside has about fifty times more rust on the inside.
crackatinny Offline
#3 Posted : Friday, 22 June 2012 8:25:43 AM(UTC)
crackatinny
Thanks Peter ;-D
#4 Posted : Saturday, 23 June 2012 7:04:23 AM(UTC)
Look up under the dash at the bottom of the plenumn. They can rust out from underneath and not be visible from outside under the windscreen.
69 rust bucket Offline
#5 Posted : Saturday, 23 June 2012 7:06:36 AM(UTC)
69 rust bucket
everywhere there rust buckets
why drink & drive when you can drift & slide
xwute Offline
#6 Posted : Saturday, 23 June 2012 7:49:09 AM(UTC)
xwute
Have a look at Rare Spares rust panels. That will give you an idea of the main areas that rust. Of course there a lot of other places that rust as well. Good luck with the job.
dirty davo Offline
#7 Posted : Saturday, 23 June 2012 8:27:11 AM(UTC)
dirty davo
i have heaps o rust replacement cuts from original cars iv cut out over th years if you need anything?? original sections that will fit, & line up correctly, including any inner sections, that you may require, that no one reproduces
wrecking HK,HT,HG,HQ/JXZ
regards DD 0412109239
