Jonesy77 Offline
#1 Posted : Wednesday, 4 July 2012 7:29:41 AM(UTC)
Jonesy77
I have a HZ Premier station wagon for sale and a donor shell,
The good things on the prem
Electric windows front and rear all work switches need cleaning
Electric tailgate which works
Air con still working
power steering
5.0ltr 308 with turbo bolt pattern
TH400 trans
3:08 ratio diff no whining that can be heard
The bad thing the body IS R/S,I have a donor shell to go with the prem the up side is the floor is in good condition in the donor shell it does have some rust pitting that hasn't gone through,the cowling panels have both been replaced with rare spare sill panels, The lower sills have had some sections cut and welded,may not be perfect but the chrome prem sill panel will cover it,the roof has had some minor damage can be fixed easily or the roof section on the original prem is good you could do a swap over.
If you have read this and your still interested i can email pics and/or try to put some on here i,m not sure what it would be worth so make an offer or if your after more info call on 0439 920 256
Happiness is not a destination but a way of life (so drive a kingswood)
