G'day All, Coulf some one tell me what dash my HXTonner has because I've been looking on Ebay and all the HX dashes I've seen don't look like mine, mine has a very wide speedo that is about a foot long but only about 2" high and it has the temp. fuel and clock all on the left, I know the tonners had HQ front ends, did they also have HQ dashes? any help would be appreciated. Thanks.
Hi Russ,
It sounds like you have an HJ dash. Are you sure it is an HX? What model is on the compliance plate?
Cheers...Dave
Hi Guys.
Qute is on the money. Only the HJ series got the 'strip speedo' (if you don't count the totally different HK).
If it also has temp gauge & clock it can only be an HJ Premier or Monaro LS.
Dr Terry |
Thanx Guys,
It is definitely an HX, I checked the chassis numbers and the spec. plate and the model says HX8W M 60. So someone must have put an HJ Premier Dash in it somewhere along its life journey . But thats no problem, I dont really care,I just wan
