HK MONARO Offline
#1 Posted : Tuesday, 12 February 2013 5:48:09 AM(UTC)
HK MONARO
Hi guys,
wanting some infomation on hk 327 type 1 bell housing, i have been told originaly they came out with clutch fork on drivers side when was is that they changed to the clutch fork on the passenger side was is it later in the type 1 or type 2.
bazza30555 Offline
#2 Posted : Tuesday, 12 February 2013 7:02:28 AM(UTC)
bazza30555
Copied this down from somewhere. Series 1 R/H/S 3858402, 3858404?, 3858405?. Series 2 L/H/S 3858403
HK MONARO Offline
#3 Posted : Tuesday, 12 February 2013 7:07:31 AM(UTC)
HK MONARO
hi bazza,
can you please explain what the numbers mean in your post.
thanks
bazza30555 Offline
#4 Posted : Tuesday, 12 February 2013 8:55:39 AM(UTC)
bazza30555
Part Numbers
#5 Posted : Wednesday, 13 February 2013 12:34:48 AM(UTC)
Some are part numbers some are cast numbers. HK V8 manual bellhousing is driver's side clutch fork afaik. The bellhousings in 10.5" are the same for left or right hand fork, the piece punched out for either side has the cast number on it for the opposite hand. I have seen some though LH side ones missing the boss for the RH clutch fork slave cylinder bracket.
