HK MONARO Offline
#1 Posted : Wednesday, 15 May 2013 7:15:10 AM(UTC)
HK MONARO
Hi, I am chasing the correct casting number for the 4 speed Saginaw that bolts to the 327 type 1 engine. from a HK
Squeak327 Offline
#2 Posted : Tuesday, 21 May 2013 6:57:47 PM(UTC)
Squeak327
The following information was posted on here by a very knowledgeable member some time ago but I just can't find the post any more.
3925656 is the main case number
3860042 is the extension housing number
3920798 is the side cover number
There were two Saginaws used in Holdens. Both are identical externally.
You may also come across a Saginaw from a later build HG which features a slightly different side cover with a cast boss for a detent switch (not used in a Holden though)."
This page was generated in 0.022 seconds.
