#1 Posted : Tuesday, 4 June 2013 10:05:31 AM(UTC)
fixed the vr horn a while a go by packing cardboard under the sensor strip, packed up again so this time drilled a 1mm hole in the round brass peg under the horn pad /steering wheel, put a brass thumbtack in it, works perfectly.
been told you can't buy the replacement parts now, and in any case its a pain having to dismantle the steering to do it.
This page was generated in 0.014 seconds.
