threespeed Offline
#1 Posted : Wednesday, 25 September 2013 3:35:32 AM(UTC)
threespeed
Hi All,
I have removed the brakes system from the HJ as part of the restoration. However I am having troubles locationg a kit for the brake proportioning valve as the rubber seal on the nut is brittle and begining to break off. I have been told that PBR never made a kit as the item was repaired by replacement.
Can anyone suggest if a kit is actually available or you know of anyone that is repairing them in the Melbourne area.
Edited by user Wednesday, 25 September 2013 9:40:44 AM(UTC)  | Reason: Not specified
76HXGTS Offline
#2 Posted : Wednesday, 25 September 2013 8:42:51 PM(UTC)
76HXGTS
Kits must be available because my local brake specialist did mine for the HX last year. They fitted all new silicone fluid compatible seals and a new pressure switch. The body was all blast cleaned and came back looking brand new.
If you can't find a place locally, give 'Perth Brake Parts' a ring.
threespeed Offline
#3 Posted : Wednesday, 25 September 2013 11:45:43 PM(UTC)
threespeed
Thanks 76HXGTS, I have gone to a few of the local brake specialists and i'm told that kits were never listed by PBR as they were a through away item.
I found a place that will send it out for repair approx $140 apparently they will strip down and find suitable seals however they will not sell the seals.
Another_HQSS Offline
#4 Posted : Saturday, 5 October 2013 11:48:01 PM(UTC)
Another_HQSS
Most brake places wont have the knowledge on a HJ any more.
I bought two PBR branded repair kits about 3-4 years ago.
The big seal on the back of the prop / brake fail module, failed and all the fluid seeped out while I had the car off the road, was a bit shocked to have no pedal when I got in to move it.
Keep trying older mechanics, brake and spares places they may have one still sitting around try there is a place in Mitcham Victoria that specialises in discontinued stock you could try. I cant remember the name though. If you find an old kit one make sure the rubber is still OK the one I got were in a sealed plastic bag and seemed OK the cars brakes work and it doesn't leak)
I have copied the holden section of the online PBR catalogue and couldn't find it I suspect it is a part used on other cars as well and was not listed as a specific holden part.
The newer places wont have them. I thought I kept the packet with the part no, but I cant find it sorry.
PBR have stopped making Master Cylinder kits as well, you can buy new master cylinders though, brake places must now have a monopoly on the parts.
They are probably a common part so if you knew the numbers you could probably get the individual seals.
Good luck
Another HQ SS
