Craigth Offline
#1 Posted : Wednesday, 25 December 2013 10:28:04 PM(UTC)
Craigth
Hi Crew,
The Auxiliary Fan for the air con on my 1981 VH SL/E 308 is not working, I have looked thru my manuals and there is next to nothing info on the way these are wired up, I have tried a circuit tester on the wires from the sender unit on the radiator, and they are Ok, I've also tested the wires going into Auxiliary Fan Relay, and they seem to be Ok, would anyone have any further suggestions on what else I should be checking.
I have had the air con switched on while checking the circuits.
Craig.
Edited by user Thursday, 26 December 2013 8:06:56 PM(UTC)  | Reason: Not specified
