#1 Posted : Sunday, 8 May 2005 11:43:00 AM(UTC)
Quick question for the electrically minded.
I have a HZ ute with a WB stato front end that I put on. After two years I have finally finished the paint work and beautiful 333ci. Now I have no idea what to do with the wiring for the head lights because when I originally put on the new front end I just cut alot of headlight wiring and now there is existing wiring coming from the stato headlights and the existing wiring from the firewall of the HZ. Should I just take this problem to a auto lec or have a go myself.
Any help would be great.
Pics of ute to come soon.
#2 Posted : Sunday, 8 May 2005 11:52:17 AM(UTC)
You have a couple or three options...
Join the wires up as they will mostly be the same colours for the same item in both front ends. All blacks are earths. Any that don't match up, run a jumper wire from battery and feed the wire in Stato front and se
#3 Posted : Tuesday, 24 January 2006 7:11:32 AM(UTC)
hi im looking for a drivers side wb headlight
#4 Posted : Tuesday, 24 January 2006 7:35:03 AM(UTC)
Hi Stuart,
Which one? The round 7" one, the square Commercial one or a WB Stato one?
Cheers...Dave
This page was generated in 0.164 seconds.
