009pk Offline
#1 Posted : Saturday, 11 January 2014 8:39:46 AM(UTC)
009pk
I purchased a vk berlina has door stap attached to door but nothing in A pillar to attach to can you buy this piece and how are the fitted inside pillar
#2 Posted : Saturday, 11 January 2014 9:09:44 AM(UTC)
You would need to source one from a wreck. They are fitted from behind (via the kickpanel area) & spot welded into place.
In your case you'd probably have to drill the spot welds out on the donor car, then plug-weld it into your car with a MIG welder.
