petered Offline
#1 Posted : Sunday, 2 March 2014 7:03:21 AM(UTC)
petered
Hoping someone can help. Disconnected battery today to clean up carrier, probably out for 2 hours. When re-connected, instruments went crazy (fuel gauge, warning lights), air conditioning / climate control doesn't work and power steering is heavy.
Any insights would be greatly appreciated.
Petered.
#2 Posted : Sunday, 2 March 2014 8:00:07 AM(UTC)
Try disconnecting the battery again, wait a few minutes & the re-connect again.
If that doesn't fix the problem, try unplugging the ABS module & see what difference that makes. If everything returns to normal (excepting the ABS & Trac light being lit) you have a faulty ABS module.
petered Offline
#3 Posted : Sunday, 2 March 2014 8:24:49 AM(UTC)
petered
Many thanks for your counsel. Will try what you suggest.
Sincerely,
Peterd
