special-k Offline
#1 Posted : Thursday, 1 May 2014 1:37:38 AM(UTC)
special-k
Hi all I was wondering if someone on here could help me with the id tags off my hz wagon its nothing special but I would just like to find out its history.
The big tag reads.
Model; 8wn35zr
Body; 962676-s
Trim; 1930-63v
Paint; 568-30521
eng l20 tran m40 rear gv4
The small tag reads.
8N35Lhh962676Z
Any feedback would be much appreciated.
Stu
#2 Posted : Thursday, 1 May 2014 3:14:36 AM(UTC)
There is no history you can tell from ID plates, only what is was originally which as you say is a HZ wagon with the most common driveline being high comp 202, trimatic and 3.36:1 banjo. It was built and assembled in the Pagewood plant. It was white with buckskin trim. It will either be a Kingswood SL or an (A9K) Kingswood (delete option) - you'll know by the badges.
JBM Offline
#3 Posted : Thursday, 1 May 2014 4:50:28 AM(UTC)
JBM
The name of the white color is "Palais White" in case you wanted a little more detail, I know the white color changed names and shades heaps of times.
It was built between Sept 77 and Aug 78.
James
special-k Offline
#4 Posted : Thursday, 1 May 2014 6:07:46 AM(UTC)
special-k
Thanks for the info guys I know I won't find its history but just trying to see if it was still in original condition which it is. Thankyou
