Simmo Offline
#1 Posted : Tuesday, 19 August 2014 7:15:46 AM(UTC)
Simmo
Im putting new rubbers back in. Do the rear quarter and door, outer seals sit on the outside or inside of the panel. The inner seals fit on the inside but I figure that wont work on the outer seals. The holes in the new seal is too big for the screws to thread into, instead it looks like the screws go through the plastic bit that holds the stainless trim, through the rubber seal and thread into the body.
Also if the seal sits on the outside it is wider than the stainless trim and will show underneath.
ht307munro Offline
#2 Posted : Wednesday, 20 August 2014 6:16:13 AM(UTC)
ht307munro
I too am interested to know. Where did you get your rubbers from?
Alex
Simmo Offline
#3 Posted : Tuesday, 26 August 2014 7:06:43 AM(UTC)
Simmo
Sorry HT, I got them ages ago and cant recall exactly where I got them.
