monman71 Offline
#1 Posted : Sunday, 9 November 2014 10:43:35 PM(UTC)
monman71
I have just bought a chassis off a HZ vacationer station wagon,there is a few things that are different to a normal one
-a gravel protector in front of the sway bar( using the front bolts)
- a little triangular plate mounted in front of the crossmember passenger side in the internal corner next to engine mount
-two brace bars mounts under crossmember to under first mount bolt either side
Would this be one of those outback packs you could order as a option?
Thanks Greg
Another_HQSS Offline
#2 Posted : Wednesday, 12 November 2014 4:25:38 AM(UTC)
Another_HQSS
Sounds like it, there should be a small metal bracket to protect the rear shock bolt as well. But if you only have the rails you wont be able to tell.
Another HQ SS
