asdf88 Offline
#1 Posted : Tuesday, 12 May 2015 7:19:24 AM(UTC)
asdf88
Apparently there are 3 types of HZ proportioning valve as follows:
P 7256 suits HZ sdn and the crack point is 225 psi.
P 7259 suits HZ wagon and utes etc and the crack point is 350 psi.
P 7305 suits 4 wheel disc brakes and the crack point is 450 psi.
My question is how can you identify which is which? These part numbers don't show on the valve itself. I want to identify the P7305. I have a HZ GTS that has a 9" with drum brakes and I want to convert it back to disk and I was thinking it might still have the old disk brake prop valve on it already.
Thanks..
This page was generated in 0.017 seconds.
