#1 Posted : Friday, 20 May 2005 8:17:42 AM(UTC)
A Fairlane AUIII can be expensive to run, but $34.36 for a new front LHS Headlight H7 globe fitted! Globe $17.34 and labour $17.02 from a Perth dealer.
Is there a cheaper place to buy globes by the box? Everytime I hook up the trailer a */X@# headlight globe goes.
#2 Posted : Tuesday, 24 May 2005 2:33:04 AM(UTC)
First it's cheaper to fix the trailer problem.
Check every earth connection etc. There's a reason that the headlight blows when you hook up. Fix that problem first.
The globes are easy enough to fit. Just remember that the oils in your skin can cause th
